I read 43 pages. The content is too much and scattered. And it is not clear which way to go from the beginning to the end. I want to use MN1 on the car and the car is Megane 2. It has an automatic air conditioner and there is an outside temperature on the watch display. The opinion of some members is that if there is an automatic air conditioner, there is no need for a BIC module or multiplexer, but most members talk about multiplexers. I want to connect pins 15 and 16 of the median to pins 12 and 13 of the obd port, without using bic. In this case, will there be a connection with the car network? And can the parameters be viewed on MN? If yes, what should I do? I have done a lot of research on this and I am curious. Thank you for your help.
