2015-11-18, 02:16
[MN1] MediaNav - uwolniona wersja jest już dostępna
Cav
Marka: Kia
Model: Sportage
Silnik: 1.7 crdi 115 KM
Wysłany: 2016-07-27, 15:58
kirirut napisał/a:
Show the content of your sys.txt
Your settings are the same as mine?
Próbowałem wielu wersji, Twojej też, niektóre ręcznie edytowałem, ale bez rezultatu ogólnego.
Jedna z ostatnich, którą mam na pendrive wygląda tak:
[device]
type="lge_ulc"
[navigation]
junction_view_type="mixed"
[sound]
csv_voice_enabled=1
[warning]
speedcam_warning=1
speedlimit_warning=1
speedlimit_warning_visual="1"
speedcam_continuous_approach_beep_when_tonal=0
speedcam_need_approach_beep_on_section_cameras=1
max_section_time=600
warn_distances="130:1000;120:850,110:750,100:650,90:600,80:550,70:500,60:400,50:300,40:200,30:150"
approach_beep_distances="100"
speedcam_visualtype=1
speedcam_soundtype=2
speedcam_soundtype_0=2
speedcam_soundtype_1=2
speedcam_soundtype_2=2
speedcam_soundtype_3=2
speedcam_soundtype_4=2
speedcam_soundtype_5=2
speedcam_soundtype_6=2
speedcam_soundtype_7=2
speedcam_soundtype_8=2
speedcam_soundtype_9=2
speedcam_soundtype_10=2
speedcam_soundtype_11=2
speedcam_soundtype_12=2
speedcam_soundtype_13=2
speedcam_soundtype_14=2
speedcam_soundtype_15=2
speedcam_soundtype_16=2
speedcam_soundtype_17=2
speedcam_soundtype_18=2
speedcam_soundtype_19=2
activated_tonal_type="alert"
overspeed_sound="!disabled"
approach_beep_sound="!alert2"
speedwarn_alt_tolerance="100"
speedwarn_tolerance="100"
speedlimit_warning_visual=1
speedlimit_warning_voice=1
[warning.driveralert.settings]
max_display_count=2
show_timeout=10
use_timeout_for_duration=1
; fixes
[speedcam_category:0]
warn_distances="120:900,90:675,70:525,60:450,40:300,20:150"
activated_tonal_type="none"
approach_beep_distances="300"
activated_sound="!alert6"
approach_beep_sound="!alert6"
overspeed_sound="!ding"
approach_beep_spoken_type=1
overspeed_spoken_type=1
use-road_speedlimit=1
; entrée péage
[speedcam_category:1]
approach_beep_sound=0
overspeed_sound=0
approach_beep_distances=0
approach_beep_spoken_type=0
overspeed_spoken_type=0
use-road_speedlimit=0
; radar mobile
[speedcam_category:2]
overspeed_sound=0
; section
[speedcam_category:3]
; sortie péage
[speedcam_category:4]
overspeed_sound=0
; feu rouge
[speedcam_category:5]
activated_sound="!alert2"
approach_beep_distances="80"
; feu rouge vitesse
[speedcam_category:6]
; hauteur limité
[speedcam_category:7]
overspeed_sound=0
; radar de distance
[speedcam_category:8]
; zone dangereuse
[speedcam_category:9]
overspeed_sound=0
; radar de tunel
[speedcam_category:10]
; passage a niveau
[speedcam_category:11]
overspeed_sound=0
; zone trente
[speedcam_category:12]
overspeed_sound=0
; stop dangereux
[speedcam_category:13]
overspeed_sound=0
; largeur limité
[speedcam_category:14]
overspeed_sound=0
; radar poids lourds
[speedcam_category:15]
overspeed_sound=0
; control alcool
[speedcam_category:16]
overspeed_sound=0
; Panneau dinformation
[speedcam_category:17]
overspeed_sound=0
; radar douteux
[speedcam_category:18]
overspeed_sound=0
; zone de dépassement
[speedcam_category:19]
overspeed_sound=0
kirirut
Silnik: 1.6 16V
Wersja: Stepway2
Wysłany: 2016-07-28, 10:01
Cav
Your settings have a a lot of unnecessary records.
They are in conflict.
Try to remove the ones that I have bold
[device]
type="lge_ulc"
[navigation]
[sound]
csv_voice_enabled=1
[warning]
speedcam_warning=1
max_display_count=2
show_timeout=10
; fixes
overspeed_sound="!ding" change to overspeed_sound="none"
overspeed_spoken_type=1 change to overspeed_spoken_type="none"
overspeed_tonal_type="none"
also for other types
Cav
Marka: Kia
Model: Sportage
Wysłany: 2016-07-29, 18:42
kirirut napisał/a:
Cav
To był chyba prawidłowy wniosek, bo faktycznie w danym (w/w) miejscu sygnalizuje już tylko dwukrotnym ding.
Dzięki za pomoc.
Ale - przy okazji przyjrzałem się dokładnie rysunkowi i mapie i okazało się, że to wcale nie jest fotoradar, tylko dziwne oznaczenie wjazdu na autostradę.
A to co brałem za ikonkę fotoradaru, w rzeczywistości jest niebieską ikonką budki z napisem "ticket".
Oczywiście żadnej autostrady tam nie ma, co najwyżej zwykła dwupasmówka.
I teraz pytanie - czy to coś w konfiguracji I-go mam zepsute po tych zmianach, czy raczej problem tkwi w złej klasyfikacji w pliku z radarami?
P.S.
Tak po analizie wpisów w Twoim pliku i w tym który miałem (z Francji), problem chyb tkwi tu:
Ty masz tak:
; S P E E D C A M - C A T : 1 Mobile Speed Camera (193)
approach_beep_distances=300
overspeed_sound=""
A ja tak:
; entrée péage
Co pewnie oznacza: wjazd na płatną drogę.
I pewnie te błędne wskazania, to jest konsekwencja faktu, że w systemie gdzieś też są zaszyte jakieś ikonki określające typy radarów.
Przyszło to pewnie w jakieś francuskiej aktualizacji.
Orientujesz się gdzie i co trzeba zmienić, żeby typ 1 prawidłowo wyświetlał się jako Mobile Camera?
P.S.2
Opisy fotoradarów udało mi się zmienić, odpowiadał za to wpis w jednym z plików w branding.zip.
Pozostała kwestia ikonek - co i jak trzeba wgrać, żeby przywrócić poprawne ikonki dla poszczególnych typów radarów?
Swoją drogą, Francuzi powinni się mocno w głowę puknąć, jeśli bez potrzeby zmieniają typy radarów tak, że nie pasują do standardowych plików z fotoradarami......
Nie wiesz Jasiu, po coo takie manewry uskutecznili?
P.S.3
Dokopałem się w necie, ze w tej francuskiej aktualizacji są zmienione kategoryzacje radarów na Euro+ - stąd problem.
http://www.my-navia.pl/viewtopic.php?t=39075
Nie znalazłem jednak odpowiedzi, co trzeba jeszcze zmienić, żeby przywrócić ikonki radarów zgodne z I-go Primo.
Ostatnio zmieniony przez Cav 2016-07-30, 10:15, w całości zmieniany 3 razy
moniek
Marka: inny
Model: inny
Silnik: inny
Wysłany: 2016-07-29, 22:40
Witajcie Panowie i Panie
Zachęcony Waszymi sukcesami postanowiłem uwolnić również swoją. Stosując się do podanej kolejności działań w pierwszym kroku zaktualizowałem system z pierwotnej wersji 2.0.9 do 4.0.3 i niby jest ok, nawigacja pokazuje nowy numer systemu, lecz nie zresetowała się sama dwukrotnie tak jak to jest opisane w innych wątkach. Po wgraniu pliku ( 1. Wgrywamy nakładkę nawigacyjną http://chomikuj.pl/jas_pi...,5355167680.lgu) z opisu jas_pika, wyświetlił się komunikat - failed to open file: temperature_f.bmp exiting aplication. Radio działa normalnie, lecz do nawigacji już nie można wejść, sławetny brak podświetlenia przycisku "zgadzam się". Próbowałem również zainstalować ,,automat,, z chomika jas_pika, niestety bez powodzenia. Mieli do pierwszej kreski i tyle. Po wyjęciu pamięci, komunikat jak wyżej. Poradzicie coś na tą przypadłość ? Na marginesie, wielkie podziękowania i szacunek dla Kolegów, którzy zgłębili tajemnice tego ustrojstwa i bezinteresownie podzieli się wiedzą z innymi.
Wysłany: 2016-07-29, 23:17
Odpal plik ratunkowy 2GB
mroziu88
Model: Laguna
Silnik: 1.8
Wysłany: 2016-07-30, 15:29
Próbowałem odblokować nawigację w zaadaptowaną w lagunie 2. Problem jest taki ze nie działa żaden z sposobów. Przy probie wgrania automatu zatrzymuje się przy piw\pierwszej kresce i znika i tak ciągle. Drugi sposób można zobaczyć na filmie https://www.youtube.com/watch?v=3fexCeJecn4. Nhttps://www.youtube.com/watch?v=3fexCeJecn4 nie mam pojecia co robię źle. obecna wersja systemu to 4.03. byla 4.02
Wysłany: 2016-07-30, 16:20
A przechodzi plik ratunkowy w całości?
Jeśli nie, masz problem z pamięcią. Sprawdź czy zadziała nakładka medi@pik
mroziu88
Model: Laguna
Silnik: 1.8
Wysłany: 2016-07-31, 06:56
Próbowałem wgrać medipak-a, ale po wgraniu brak reakcji. Jeżeli chodzi o plik ratunkowy może być ten z Twojego chomika? navigation_restore_fat32.zip
Ostatnio zmieniony przez mroziu88 2016-07-31, 07:26, w całości zmieniany 1 raz
kirirut
Silnik: 1.6 16V
Wersja: Stepway2
Wysłany: 2016-07-31, 20:04
Cav,
speeedcamera icons are located in
branding.zip\ui_lg_renault\800_480
1. ico_speedcams.bmp - warning icons in cabin
2. ico_speedcams.spr - (setting "Stripes = 61" in this file meens height of icon)
3. speedwarn.bmp, speedwarn_list.bmp, speedwarn0.bmp, speedwarn0_list.bmp, speedwarn1.bmp, speedwarn1_list.bmp, speedwarn2.bmp, speedwarn2_list.bmp, speedwarn3.bmp, speedwarn3_list.bmp, speedwarn4.bmp, speedwarn4_list.bmp - icons on map
branding.zip\ui_lg_renault\common
1. speedwarn.bmp, speedwarn0.bmp, speedwarn1.bmp, speedwarn2.bmp, speedwarn3.bmp, speedwarn4.bmp.
2. speedwarn.spr, speedwarn0.spr, speedwarn1.spr, speedwarn2.spr, speedwarn3.spr, speedwarn4.spr
extended types http://sendfile.su/1254362
use to view iPAQ 31x Image Explorer
original from medianav. Icons countdown starts with 0 to 32.
speedcams from 0 to 15 have their own icons, from 16 to 30 same picture
Plik ściągnięto 65 raz(y) 38,98 KB
extended types
Plik ściągnięto 60 raz(y) 109,77 KB
Ostatnio zmieniony przez kirirut 2016-08-01, 12:11, w całości zmieniany 4 razy
Cav
Marka: Kia
Model: Sportage
Wysłany: 2016-07-31, 21:12
kirirut napisał/a:
Cav,
Icons speeedcameras are located in branding.zip\ui_lg_renault\800_480
Te już podmieniłem na te, do których link podawałeś w tym wątku, zakładam że były prawidłowe.
Niestety - nic to nie dało i nadal radary mobilne (czyli typ1) są widoczne jako niebieskie ikony wjazdu na autostradę.
Ostatnio zmieniony przez Cav 2016-07-31, 21:13, w całości zmieniany 1 raz
kirirut
Silnik: 1.6 16V
Wersja: Stepway2
Wysłany: 2016-08-01, 11:56
Cav napisał/a:
Excuse me. Also you need place in folder branding.zip\ui_lg_renault\common files from my zip http://sendfile.su/1254362
Then all will be OK.
Ostatnio zmieniony przez kirirut 2016-08-01, 11:58, w całości zmieniany 3 razy
kirirut
Silnik: 1.6 16V
Wersja: Stepway2
Wysłany: 2016-08-01, 12:04
Cav napisał/a:
For compare
extended types
Plik ściągnięto 37 raz(y) 109,77 KB
from French branding.zip
Plik ściągnięto 48 raz(y) 78,84 KB
Cav
Marka: Kia
Model: Sportage
Wysłany: 2016-08-01, 15:57
kirirut napisał/a:
Cav napisał/a:
For compare
Tak, dokładnie - wyświetla się ta druga ikona z francuskiej wersji.
Nie wiem co jeszcze mogę zrobić, gdzie jeszcze te może siedzieć?
kirirut
Silnik: 1.6 16V
Wersja: Stepway2
Wysłany: 2016-08-01, 17:24
Cav napisał/a:
and
Check. if there is folder \Storage Card4\NNG\ui_lg_renault and \Storage Card4\NNG\ux\, delete them.
Ostatnio zmieniony przez kirirut 2016-08-01, 17:42, w całości zmieniany 2 razy
Cav
Marka: Kia
Model: Sportage
Wysłany: 2016-08-01, 18:45
kirirut napisał/a:
Teraz trafiłeś.
Pomogło dopiero usunięcie folderu \Storage Card4\NNG\ux
Dzięki wielkie, ikonki wyświetlają się prawidłowo.
agent
Model: Clio
Silnik: 0.9 Tce
Wysłany: 2016-08-16, 12:38
W zeszłym roku uwolniłem z powodzeniem moje MediaNav w Clio. Teraz kolega mnie prosi o to samo, również w Clio.
Temat sobie odświeżam, bazowałem wtedy na MEDI@PIK_12_2014. Uwalniałem z wersji 4.0.3. Tym razem oprogramowanie jest chyba starsze (jeszcze nie zaglądałem ale się przygotowuję).
1) Czy mogę wgrywać MediaPIK na starsze wersje OS czy trzeba na 4.0.3? Jeśli na 4.0.3. to potrzebuję pewnie restore 4.0.3 dla renault, czy tak?
2) Czy coś się zmieniło od zeszłego roku jeśli chodzi o pliki. Mogę użyć tych czy coś lepszego już wyszło? http://chomikuj.pl/jas_pik/MEDI*40PIK_12_2014
Wysłany: 2016-08-16, 13:37
Na razie polecam tą samą wersję medi@pik oraz zmianę za pomocą wersji 4.0.3.
Na starszych wersjach są problemy.
Za jakiś czas przygotuję wersje na wyższe wersje oprogramowania.
Ale do dziś 4.0.3 jest najbezpieczniejsza.
agent
Model: Clio
Silnik: 0.9 Tce
Wysłany: 2016-08-16, 13:48
Dzięki,
Pewnie pisałeś to już do znudzenia (podziwiam Twoją cierpliwość) ale czy aby zrobić upgrade do 4.0.3 to mam użyć pliku Renault_403_restore.lgu czy sam upgrade.lgu?
Na razie znalazłem tylko ten link do restore: https://www.dropbox.com/s...OXq6P7Be4a?dl=0
Czy ten plik będzie ok?
Wysłany: 2016-08-16, 14:13
Najlepiej zwykłe upgrade ale jesli nie zadziała to restore
Cav
Marka: Kia
Model: Sportage
Wysłany: 2016-08-16, 16:45
kirirut napisał/a:
Cav napisał/a:
and
Korekta - pomogło tylko na ikonki wyświetlane na mapie.
Ale już alerty z fotoradarami nadal wyświetlają ikonkę wjazdu na autostradę.
Gdzie to jeszcze może siedzieć?
agent
Model: Clio
Silnik: 0.9 Tce
Wysłany: 2016-08-16, 17:02
Troche sie juz gubie w tych plikach. Jeden restore ma 128 MB a inny 2 Gb. Jakby komuś się chciało odnaleźć dobry plik z samym upgrade (nie restore) do Renault 4.0.3 to byłbym wdzięczny. Szkoda ze nie mozna 9d razu MediaPik bo już bym wszystko miał i wiedział
Wysłany: 2016-08-16, 18:10
Restore 2Gb służy do odratowania jeśli zszarzeje Ci klawisz nawigacji ( zgadzam się) .
Standardowe pliki 4.0.3 są znacznie mniejsze - około 70 MB a jesli powraca się z wyższej wersji 150 MB
agent
Model: Clio
Silnik: 0.9 Tce
Wysłany: 2016-08-17, 09:36
Znalazłem takie pliki:
1) upgrade_root.lgu - 128 MB w opisach było że służą do downgrade z wersji wyższych do 4.0.3.
link do pliku: https://www.dropbox.com/s...OXq6P7Be4a?dl=0
2) upgrade.lgu - 82,1 MB oraz upgrade_root.lgu - 87.6 MB w opisie było że do Renault restore
link do plików:
https://mega.nz/#F!yo81yIIT!NiZaRmr3fXuUXjkecvCdXA
3) navigation_restore_fat32.lgu - 2 GB - ten to rozumiem jest ratunkowy jakby inne metody zawiodły.
Wydaje mi się że aby zrobić upgrade z wersji niższej do 4.0.3 to powinienem spróbować tego drugiego ale nie jestem pewien.
I z tego co napisałeś to powinienem spóbować
- najpierw upgrade.lgu z linka 2
- jak nie da rady to upgrade_root.lgu z linka 2
Czy aby aktualizacja zastartowała to w tych plikach upgrade_root.lgu trzeba usunąć wyraz root czy zostawić jak jest?
Wysłany: 2016-08-17, 10:20
Najlepiej 1.
Bez zmiany nazw.
Plik 2GB jest ratunkowy wyłącznie gdy "zgadzam się' jest szare - nie podświetlone i nie uruchamia się nawigacja.
agent
Model: Clio
Silnik: 0.9 Tce
Wysłany: 2016-08-17, 11:12
Zanim odpowiedziałeś to poszedłem do auta. Ten upgrade.lgu z 2 linku chciał się aktualizować na 4.0.4 więc zrezygnowałem. Miałem wersję 4.0.2. Zaryzykowałem i zapodałem MediaPik od Ciebie na 4.0.2. Wszystko zadziałało póki co.
Bardzo dziękuję za rady i odpowiedzi.
Ostatnio zmieniony przez agent 2016-08-17, 20:53, w całości zmieniany 1 raz
